Yes. With internal transfer switch.
in roadtreks defense-when my inverter/charger on my microwave lights ,tv,and blue ray player all go on. i never worry about unplugging
do they have a 6000 watt one?
Yes, I would say that's about right. I never received any power saver info from them either by e-mail or phone conversations.Great information, thanks for posting it. Generally confirms the earlier Roadtrek statements, but contradicts a later 3 amp statement. Do you find that an unattended, unloaded, on, module goes dead in about 1.5 days?
I am an Ecotrek owner having multiple battery & volt start issues from day one. My mechanic was told by a Roadtrek tech on July,19,2016 that the batteries do indeed pull 6 amps/hr just to operate.
I guess I missed something a while back - where is this drawing down to 20% is OK on AGMs coming from?
Well, that looks like nonsense to me. According to the table, the life cycles drop almost in half. While they're working, yes I guess the available aH doesn't drop that much (12%), but the end result is dead batteries in half the time as treating them per the guidance.
I have 220 AH AGMs under the hood on my Sprinter and if I need an average of more than 110 AH per day but less than 176 AH it makes complete sense to simply draw the batteries beyond 50% and replace the batteries more often. No need to try to lose storage space for more AGMs or to spend money on lithiums.
Yes, it costs 12% more than adding two more AGM batteries but that is not a big penalty to avoid adding two more batteries.
The "risk" of hammering AGM batteries when going beyond 50% is not real, it is a long held idea that is not backed up with data.
Costs may be lower for lithium battery packs. This site has premade packs or give you everything you need to build one, the size you want including instructions and phone help.
<b>- 12 VOLT PACKS</b>
Even more if you build the pack yourself. <$5000 for 900AH.
