CR Laurence Window Hinge Attachment Maintenance
Seeing the occasional post here and elsewhere regarding the hinge-to-window bond failing on a CR Laurence crank open window has me planning to do some maintenance. Right now it appears the window bond to the hinge is good, but looks may be deceiving. The windows do operate and seal properly, so that mechanism and alignment appear to be good.
I could try to separate the glass from the hinge and reseal. There is much discussion on adhesives, from the CR Laurence product (some poor reviews), 3m Window weld, and others.
Or I could simply add a strip of Gorilla Tape or equivalent, and replace every few years when the UV deteriorates to the tape.
Any experience or suggestions?
