markopolo-ClassB
Senior Member
I've been looking into buying or making a table to put my laptop on once we've set up camp. In the past I used the dinette and put the laptop away between uses.
You've probably seen these on TV:
It's easy to get in and out of the chair:
It stores behind the drivers seat:
Just prior to finding the Tilt-a-table above I had scavenged these parts:
Table top with bracket that would fit on 2" pipe:
Close up of part that fits onto a 2" pipe:
The top can be turned however you need it and you can lock it in place:
I'll try out the Tilt-a-table this season. It might even come in handy outside.
I'll save those other parts and will build the custom table if the tilt-a-table doesn't work out.
