RT outside shower
Ken Calhoon
Joined
Jul 23, 2018
Messages
2
Location
CA
I need to replace my Dura Faucet in the outside shower panel. Anyone know how to access the shower compartment?
20014 RT Adventurous
If its a normal ROADTREK, you simply unlock the door with one of the small keys that came with your unit.
If youncannot find the key, you simply crawl underneath with a flashlight & a knife/flat blade & unlock the tab.
How do you even know that you need to change out the faucet head?
Or am I missing the issue here?
Welcome to the forum Ken!
I don't have your rv model, and the outside shower is one of the few things on my van I haven't had to replace. But I may have the same outside shower faucet, maybe not.
Does it look like the one at the above right?
I am confused Ken.
If you were able to take that photo, you already have access to the outside shower.
And the spigot for the shower faucet is sitting below & in the middle if the hot cold controls.
You simply mount the existing hose with some thread seal.
If that is an old photo & the door is locked & your don't have the key, you simply lie on your back & with a flashlight & a screwdriver & push the flat blade arm of the lock to an open position.
If i have misread your question, I apologize.
I screwed up , my apology - got this message in my inbox;
Comment: Access to plumbing was behind an access panel under rear couch/bed. Cannot replace the faucet unless plumbing lines are removed.
Oops!
  • and much more...
Try RV LIFE Pro Today
Back
Top
