I recently purchased a 2022 Era 70A with 2 solar panels on the roof. There is no documentation from Winnebago as to whose they are or their output details, not even on the window sticker, even though they supposedly came from the factory, installed by the factory.
I believe them to be 100 Watt Zamp units. I would like to know their output voltage to the controller which is also a Zamp 450 W unit. The info being displayed on the controller doesn't make a lot of sense, but it may be some sort of abbreviation. The Zamp controller info brochure is not very detailed about what readings should be...somewhat understandably because the authors would have had no idea which or what panels it could have been hooked up to.
Anyone owning a similar unit who has figured out what panels Winnebago furnished, and what any specs may be, such as output voltage, I would very much like hearing from. Thanks!!
