markopolo-ClassB
Senior Member
What happens when you have multiple similar DC input voltages all functioning at the same time?
Example:
Genset running 14.4v from converter and engine idling with say 13.9v from the alternator via a diode type isolator
My guess is that loads will see 14.4v at the batteries until the amperage draw is great enough to reduce that voltage. Then there's the next level of support at 13.9v ................. ?
Or is there a blending of the available amperage?
I haven't given it much thought and a Google search hasn't turned up anything yet. I would like to know though.
We can have multiple DC inputs, alternator, generator, solar all with different output voltages or a single input wired in such a way that there's a voltage on one set of wires compared to another set. In my van for example I can parallel coach and chassis batteries via two paths at the same time. One path would have almost no voltage drop and the other path, through the isolator, will have some voltage drop.
Any ideas as to how multiple DC input voltages work together simultaneously?
Example:
