Do you have an iPhone? If so the following steps may help you avoid unwanted incoming calls, you may want to read the following. This will help you BLOCK UNWANTED CALLS.
Step 1. First, Turn on your iPhone and click on SETTINGS.
Step 2. Pan down to "DO NOT DISTURB" and click.
Step 3. TURN ON DO NOT DISTURB and keep off Scheduled unless you are getting calls after 1-AM.
Step 4. Now click on "Allow CALLS from ALL CONTACTS
Now only folks who are on your contacts list will ring your iPhone as an incoming call. Anyone NOT in your Contacts will go to your iPhones internal answering machine.
Meaning you will see a number in the recent calls directory, The call did not ring on your phone. Now you have some options, to BLOCK all future calls from that number? Check the caller to find if its a call you want or NOT?. Did they leave a message? calling back?
As for myself, NO Message left for me then NO time to call them back.
Now you will also need to in your settings of DO NOT DISTURB within three minutes or it will ring your phone.
GOOD LUCK and keep me posted on any iPhone ideas that you may have.
Here is the APPLE iPhone 800 helpline for iPhone problem issues.
APPLE IPHONE 800-694-7466.
