mlts22-ClassB
Senior Member
- Joined
- Sep 13, 2012
- Posts
- 978
Since I boondock on weekends for the first part of the year, I'm looking for a well-made cargo trailer with a total weight loaded under 3000 pounds. This would be initially used to bring supplies in case of an ice storm, then used as storage. Estimated dimensions, 4x8, 5x8 or 5x10.
A couple mods I plan to do:
1: Reinforce the inside, then install Rotopax mounts on the sides. This would allow me to bring a good amount of additional fuel initially, and once the trailer is parked/secured, use a hitch mounted cargo rack to haul empties for refilling.
2: Install high efficiency solar panels on the roof. Inside, I'd use a MPPT controller (so I can use every watt that hits the panels) and two sets of 6v AGM golf cart batteries. To get the power where it is needed, a 2000 watt PSW inverter will do that job. While I'm gone, the batteries will charge from the panels, and when I'm onsite, the onboard batteries will be able to get charged, offsetting the drain from the furnace. It won't power the A/C or microwave, but it will be good enough to keep the house batteries topped off without having to subject others to generator noise.
3: Reinforce the doors for better security. Crime isn't a big issue, however, hockey puck locks, a stout lock on the trailer hitch, and chained wheels will guide people with larcenous thoughts to another target.
What I'm wondering is if anyone has done something similar, and what is a good brand of enclosed cargo trailer? I've seen some brands that might look OK with smooth aluminum sides, but inside, it is amazing the thing even stays together.
