Definitions as I understand them, with explanation.
Converter--Changes a AC voltage to DC--In the case of RVs it is 110v AC to 12v nominal DC. They are unregulated transformer types in days of old. Now days they are commonly referred to as power supplies or regulated power supplies and are used in lots of applications in industry. The old converters needed a battery for stability, but not to generate power, the newer power supply types do not need a battery reference to hold voltage.
Battery chargers change AC power to DC power just like the definition of a converter. Early battery chargers were fixed voltage and construction just like a converter and did not need a battery to generate power, but did for stability.
The bottom line is that a converter is a battery charger if it is at the right voltage for the battery being charged. A battery charger is also a converter if it is supplying power to an RV.
The definitions get more involved when battery charger technology moves forward. Multi-stage, smart, intelligent, whatever, chargers use electronics to regulate the output voltage to better take care of the batteries they are charging. In an RV, they are also mulivoltage converters because they are supplying power to the RV at the same time, if you want to use that definition. Or you could just say you have a battery charger only, and the van power is coming from the battery, which is sometimes true and sometimes not in reality.
All this is well and good, and we can mostly agree that you do need a battery in the circuit if you have an old school converter that is also used to charge the batteries, but for stability not to make it function. If it is a very old system, there may be a chance that the converter would only power the coach DC circuits and not be connected to a coach battery or there may not be a coach battery. In this case the coach battery would only charge from the alternator. I have heard of such systems but never seen one.
What I still don't get is that you state a current day converter could be disconnected from a battery, which is technically true if such a converter were ever used in an RV. It would basically be the previously mentioned "power supply" and would be used only for single voltage. The currently used converter/inverter/chargers are all multistage chargers and they also supply power to the RV. Many also have an inverter to supply 110v off the batteries.
I would like to hear if there really is a converter/charger that does not need a battery reference to initiate, and still does multistep charging as many Roadtrek owners would be able to get rid of the AGM battery in their lithium systems with one, I think. As I mentioned about the brands I have owned, none of the multistage chargers/converters will start without a battery, and I have never heard of an RV coming with a converter (power supply) that does not need a battery to run. I will point out that the addition of a fixed voltage power supply was one of the very early suggestions that was discussed here on the forum in relation to the Roadtrek problem of not being able to restart their lithium batteries after a shutdown, before the did the AGM battery.
