Old 08-30-2021, 04:59 PM   #21
Batteries=China, Everything else Amazon. Everything is in and hooked up and working except the batteries and MBS which I get end of Sept.
larrylwill is offline   Reply With Quote
Old 09-27-2021, 04:31 PM   #22
I have one, located in mass, zip 02739 if you’re interested, $200
kpbanker is offline   Reply With Quote
Old 09-27-2021, 06:31 PM   #23
Originally Posted by Mark_C View Post
2014 Roadtrek CS Adventurous. Inverter is failing - looks like control switch panel is failing. Woudl like to do a direct swop with same unit - so its an easy swop out / swop in. Having trouble sourcing the original unit. The original factory inverter/charger is 3KW unit from Microgreen Model MG-CI-AXA-3000-12-DC1 1420. This is a "badged" unit from China. Microgreen no longer supply it. The other label on the unit has this info: Model No: LW3000W-12-C, Input: 120VAC, 60Hz, Output: 120VAC, 60Hz, Barcode ||, 12302-14051470025.
It looks very similar to this unit, both specs and visually: https://zlpower.en.made-in-china.com...ter-1-6kw.html
Does anyone have advice on how to find one of these units?
Many thanks
MarkC
Mark, a RT owner has one listed in the For Sale Swap Section…says it is new, and comes from same Model you have.
Ron J. Moore
'15 RT210P
Old 10-05-2021, 04:45 PM   #24
While I agree that RT going out of business was a drag, most of the latches and fixtures are generic and available on line through Amazon or other on line source. The problem, of course, is determining what you need from the rather sketchy descriptions…it took me 3 tries and returns to get the correct push button bathroom latch for example. On the other hand I replaced the hot and inefficient bed reading lamps with great LED units.
Old Today, 08:56 PM   #25
Default 2015 Roadtrek Zion Inverter/Charger failure
I have a 2015 Roadtrek Zion with the Microgreen original Inverter Charger. Recently while camping and returning from a day trip with the refrigerator running on Lithium Battery power. We plugged into shore power and were faced with a melting wire smoke behind the refrigerator of unknown origin. The 110 system while on shore power was gone, the charger/inverter had the "the blue screen of death" and an alarm signal. I turned off the charger inverter which stopped the melted wire smoke. Unplugged from shore ppower, restarted the inverter/charger, checked the 110 power outlet and had battery powered 110 volt but no Air Conditioner oor microwave power. The inverter is now totally dark, will not power up on shore power. Still have battery power to run refrigerator. Any ideas/suggestions to diagnose the problem with the inverter/charger? the reset buttons on the back of the unit dont appear to have tripped. Im new to Roadtrek, but have read prior forum input on Roadtrek electrical problems.
Scott_792 is offline   Reply With Quote
