Are we going to start seeing parallel lead acid & lfp battery setups now with the drop-in lithium batteries?
There's already a commercial option for this:
https://www.bos-ag.com/products/lithium-extension-battery
The 110Ah Trojan Trillium LFP battery -
https://www.trojanbattery.com/pdf/datasheets/27_Lithium_12.8-110.pdf - combined with 440Ah AGM would fall into the suggested 4 to 1 range of the bos-ag.com setup.
I'm not thinking of any special setup here, just a typical paralleling of batteries
with the full realization that the lithium battery will be float charging the AGM most of the time. No buttons to push, no switches to toggle, no user management of the system, no decisions to be made etc.
We often try for perfect but convenience, economy and extended run-time, not perfect, would be the goal here.
There is probably a pretty high probability that is the system that Hymer was raving about a while ago for the European market. This is what precipitated the question of building similar, which Harry did, but with more charging control.
I think the questions that were asked then would still apply, though, even if we have bit more data now about the system.
It would be interesting to see how the currents flow on charging and discharging, especially out and in of the lithium, as it seems like it would be hard to have the AGM take priority in charging. One would think the lithium would fill first at a 14.3v or absorption voltage that the AGM would want, unless the lithium batteries self limit current going in. It says the lithium would discharge first, which would be expected, and they list a max amps but don't say if it is internally limited to that level. The float they say the lithium gives the AGM might be on the high end of the range, but probably not horrible, but they might also be limiting that internally.
Most of the AGM system chargers have absorption times in the 4 hour range, so the lithium would see that voltage and time essentially every charge cycle. The 4 hours is also not really enough to totally till most AGM discharges so if that was increased by using an amp based charger that time would greatly increase for the lithium. This was why Harry used the 12v to 12v charger in his setup, so the AGM would get fully charged off the lithiums. The other thing the 12v to 12v did was limit the charge current to the AGMs form the lithium, as when I tested that with small batteries the current from the lithiums went way too high ass soon as the charger was shut off if the AGM wasn't completely full or at least over 85%. That my be why this new systems lists max output so low and may limit it to that. If they limit that current, they would eliminate the largest part of the need for the 12v to 12v charger, I think.
At the 4 to 1 ratio, it probably would work best for someone with 300 watts of solar or more and moderate, maybe 50ah, daily use. In that case the AGM would rarely get discharged much at all and the solar would like the low internal resistance of the lithium battery. This would, I think, greatly increase the life of the AGM bank, and you would still have it there for reserve in cloudy weather.
Once power use gets to the point of bigger discharges of the AGM, I think it gets more difficult to predict gains and losses in life for both the AGM and lithium. It will be interesting to see if anyone puts a data logger on one of the Hymers when they get out, and if they are this system, to get some real world information.
The simplicity of the system would be a huge plus, and over the normal time an RV lasts any weaknesses may not be big enough to make a difference. We do know that ARV and Roadtrek both tired full lithium systems with drop ins and quickly went away from them, but don't really know what the issues were for them, if any, but those could have been different control systems.
