Gerry's question about inverter low voltage cutoff vs autostart, and a past discussion about the reprogramming of the low voltage cutoff of the Roadtrek frigs brings up a kind of "catch 22" question, which I also noticed on the bench as I was testing our new system.
The inverter low voltage cutout is fixed setting at one voltage, sometimes with a time at that low voltage being needed (to keep it on during high surge startups?)
In the world of smaller inverters that run small loads like many of us have had in the past, the low voltage cutoff could pretty easily be set to keep the inverter from running the batteries lower than we wanted to take them. If you have a reasonable amount of batteries (especially AGM or lithium) the voltage drop running small loads is only a couple tenths of a volt, so you could set the low voltage cutoff at your desired minimum discharge and be pretty accurate. It would trip a bit early with loads on, but not much.
Now if you take a look at the bigger inverter, bigger load, systems, everything changes. With big loads like air conditioning, you can easily lose considerably more than a volt of voltage even with full batteries, and it gets worse as they get discharged. If you want to keep your batteries above 50%, like many do, you might set the low voltage cutoff at 12 volts to assure holding the 50%. In this case you could trip the cutoff with full batteries by running a big load. If you set the low voltage cutoff low enough so you can run the big load and have it cutoff at about 50% with the load on, you will have it set so low you could have totally dead batteries if you just have low loads, or had the inverter on by mistake taking parasitic power.
It would seem that it might be a good idea for the inverter low voltage cutoff be a load modified setting (perhaps with a settable lowering of the setting with increased load-maybe .1 volt per 10amps or something like that). That way it could be set to be effective, and useful, over the entire range of use
I don't know of any inverter that currently works that way, but there may be some.
