Old 01-17-2024, 03:18 PM   #1
@Michael's Avatar
Default Integrating Garnet SeeLevel sensors into DIY van monitoring
My Coachmen Crossfit came with unreliable tank sensors. Garnet SeeLevel tank sensors integrated into my DIY camper monitoring system would be a big improvement.
My current monitoring system is centered around MQTT and Node-Red running on a Victron Cerbo GX and a Nextion touch screen, with ESP32's where needed for reading sensors and communicating between devices.
Options for integration include buying a SeeLevel control panel with any of Bluetooth, RV-C, or NMEA2000 interfaces, the latter two of which directly interface with Victron's Cerbo units and/or Raspberry Pi running Victron's OS.
Reading the sensors/sending units directly, without the Garnet control panel also seems to be possible - based on this post in a Raspberry Pi forum, where one of the participants (Jim G) figured out how to trigger and read the tank sensors/sending units directly.
I bought a couple of SeeLevel sending units and successfully dummied up a test using an ESP32 to trigger and read the sending units and a circuit similar to the one designed by Jim G. in the Raspberry Pi forum. It's working on the bench with two SeeLevel sensors attached to a water jug.
It's too cold to work out in the camper, so I'll not know if it's reliable in the real world until it gets quite a bit warmer. In the meantime, I've rearranged my display to accommodate tank gauges (lower left corner):
I figured I could either use (boring) green bars to show tank levels, or an appropriate set of emojis.
My code and a description of the circuit are uploaded to Github. To fully integrate the sensors, I'll need to modify my code to encapsulate the data into JSON formatted ESP-NOW packets, and come up with an algorithm to properly interpret the data (likely in Node-Red).
I'd also like to put a bit of protection on the 12v circuit feeding the sensors. I'm not sure how tolerant they are of voltage spikes and anomalies. I've no idea how to do that though.
2019 Coachmen Crossfit
Old 01-17-2024, 05:59 PM   #2
Urlauber's Avatar
I have no idea what I just read, but your display looks really cool.
I have some old, but functional tablets that would be just great for such a setup (like a Galaxy Tab S2). Maybe a project for another year...
Not to derail your thread, but... Do you have any experience with/opinion of the Mopeka "Pro Check Universal Sensor" for such a purpose?
2022 Thor Rize 18M
Old 01-18-2024, 06:51 PM   #3
@Michael's Avatar
No experience, but that Victron supports them with their Cerbo product line suggests to me that they're OK.
Old 02-05-2024, 01:21 PM   #4
@Michael's Avatar
Updates on this project:
I'm now using a circuit based on the one in the original post in the Raspberry Pi forum. It's reliable with three sensors in parallel at the far end of 20ft. of 20ga, wire, so it should work OK in the camper.
I decided to inline a 12V-12V buck-boost converter to help ensure that the sending units see a clean, stable voltage source.
My code and a description of the circuit are uploaded to GitHub. To fully integrate the sensors, I'll need to modify my code to encapsulate the data into JSON formatted ESP-NOW packets, and come up with an algorithm to properly interpret the data (likely in Node-Red).
The data returned by the SeeLevel sending units is a series of bytes:
Code:
Byte 1: Unknown, perhaps a sensor ID
Byte 2: Checksum
Byte 3 - 11: Number from 0 -> 254
                   indicating the 'fullness' of each segment of the sensor
                   starting from the topmost segment
Byte 12: Always '255'
Turning that series of bytes into a somewhat accurate percent-full number in NodeRed is still TBD.
Old 02-05-2024, 07:58 PM   #5
I use the Mark 1 Eyeball Tank Measurement System (METMS 1.0). 100% accurate and works perfectly every time.
Old 02-06-2024, 05:51 PM   #6
@Michael's Avatar
Unfortunately 2 of 3 thanks are not translucent, and the one that is, is not readily accessible.
Old 02-06-2024, 10:34 PM   #7
Right - that makes sense. Your system looks very nice. I'm still using an old JRV "dummy light" system, but I don't like to rely on it alone.
Old 02-07-2024, 05:40 AM   #8
I turn the water off, push down the pedal shine a flashlight in the hole and See Level. 100% accurate. Does not work with fresh or grey tank. I put a See Level system in a bus conversion 20 years ago, the external sensors do work well.
Old 04-05-2024, 01:32 PM   #9
@Michael's Avatar
I've got the custom Garnet SeeLevel tank level reader installed and working.
I decided to consolidate my microcontrollers onto a 'motherboard' with 12v and 5v rails, so that I don't have individual voltage regulators on each board. The 'motherboard' is powered by a 12V buck-boost power supply set to a constant 12.7V. A 5V buck converter powers the 5V rail from the 12V rail. Each 'daughterboard' has access to regulated 12V and 5V supplies by virtue of the header pins. It's all stuffed into a plastic box with a screw-on lid.
The tank reading microcontroller and digital electronics (high-side MOSFET, NPN transistor and a handful of resistors) fits on a small proto board. It picks up 12V and 5V from the 'motherboard' via the header pins and connects to the sensors via the JST connectors on the left of the board.
So far two of my four microcontrollers are reworked onto the 'motherboard'.
I'm feeding the tank data into Node-Red running on a Cerbo GX, where it's forwarded to my camper monitoring screen and to my cloud dashboard/phone app. Node-Red requests a tank read and updates the displays every 15 minutes. The phone app has buttons that request an immediate tank read for cases where I want real-time tank levels (when filling the tank, for example).
For more accurate readings, each sensor could be calibrated by filling each tank to a known number of gallons and adjusting the % reading. The Garnet control panel does this automatically. I'll do this via fixed offsets in Node-Red - maybe. Even without calibration it's more accurate and reliable than the OEM gauges.
If I bought a new $150k van I would have all this from the factory. That wouldn't be any fun though.
More details are here:
https://janke.photography/2024/02/25...d-tank-gauges/
Old 06-30-2024, 10:04 PM   #10
@Michael's Avatar
Related:
There is an ESPHome component available that reads SeeLevel gauges. It still requires custom circuitry though.
https://github.com/j9brown/esphome-seelevel
Compared to what I've built, it's closer to being usable by less technical persons.
Old 06-30-2024, 10:13 PM   #11
I think I am glad we used the Seelevel display. The good was no wires to run as you can use the original wiring from OEM in tank sensors. 3 tanks, propane, pump, water heater. Probably over 10 years and no issues at all with it.
Old Yesterday, 06:38 PM   #12
@Michael's Avatar
Yep. That would be the best choice for nearly everyone, and if integration with a Cerbo GX or other monitoring system is desired, the displays with NMEA-2000, RV-C, or Bluetooth would be easier to integrate.
