To recharge an RV battery bank, we can use the following and they all make sense:
1. Engine primary alternator
2. Solar panels
3. Auxiliary generator
4. Shore power
5. Wind generator
6. Engine secondary alternator.
Each one of them have pluses and minuses which will vary with different scenarios but to make a statement that one of them makes no sense is rather arbitrary. I could say that a second alternator makes no sense just because it doesn’t for me but solar does. In case of Avanti I can see that the second alternator make sense because his primary alternator doesn’t charge his batteries. In your case when you tend drive a lot it makes sense as well, but for me it doesn’t, but it still make sense.
You are very proud of your Advanced RV but statistically they are the B-class market outlier in price and design, they don’t represent the main stream so coming from that corner and say that solar makes no sense is “interesting”.
I have 300W of solar with reasonable loads and the solar system for us was absolutely perfect in meeting our camping needs.
Did I say anything factually wrong? The Wynn's said the could get 50-60 amps of there solar panels that obviously have to be tilted and oriented to the sun. That is possible in a dessert dispersed camping site with plenty of sun and then just peak hours. That's not the case just about anywhere outside of the Southwest. Plus, under rare circumstance can you get 960 watts of solar on a B and what you can get is often shaded by rooftop equipment and even the hiked up awning assembly on Sprinters. At best solar is a battery maintainer for storage for low amp battery banks. It is inefficient in cost benefit otherwise on a B, including the primary engine alternator that still outperforms solar. Avanti's primary engine alternator indeed charged the batteries at one time but he installed a more efficient second alternator as did Booster and both with AGM batteries.
The sun is unreliable to depend on most the the United States. To use it you limit yourself in camping sites. You can control, depend and predict your usage on a primary alternator, a secondary dual alternator or shore power.
"Reasonable loads" is a compromise phrase for conservation. I'm in to no worry, 24/7 use of my B with all electrical systems 120VAC outlets, microwave, coffee maker, curling iron, or any other electrical device always available without firing up a generator. You don't have that I guess so you have no concept of the freedom you enjoy having that. Just overnight in a Walmart parking lot and pine.
I've got 420 watts of solar panels in about the most efficient setup you can with individual MPPT controllers for each panel. I can measure the input accurately to the amp on my Silverleaf controller and I have the capability to set up a computer for more accurate monitoring information and I have come to my conclusions with factual information and not supposed, theoretical, or wished for information.
So, I am an outlier as your excuse to refute me. You are an outlier as well with you DIY B. What is bad about being an outlier in design. Advanced RV has had the benefit of a team to put together a B with the input of just about every customer to build on. They cost more because they are better at construction and their attention to detail both concealed and in sight. They generally have more than any other B just in regards to standard features. The customer gets exactly what they want from initial ordering of the van from M-B, to their own finishes, and custom features they bring to the table. I got exactly what I wanted including the electric articulating beds which I proposed and after 2-1/2 years I haven't added anything to my B except 3M Command Hooks and a beer bottle cap opener. I did voluntarily upgrade from the Nations dual alternator to the Delco-Remy. I didn't have to do it, it was just a desire and now I am one of the few who know the differences. I can afford it just as well as the 10 times greater retirees that buy half Million dollar Class A RVs. I just wanted that luxury in a B.
