hbn7hj
Senior Member
1 lithium battery, 1 60 amp lithium charger. Charge current 59 amps
2 lithium batteries in parallel, 2 60 amp lithium chargers in parallel. Charge current 95 amps.
4 lithium batteries in parallel, 2 60 amp chargers and 1 80 amp charger in parallel. Charge current is 110 amps.
Charging voltage stays at 13.8 volts till full when it will increase to 14.5.
I assume the reason for the charge rate not nearing 200 amps is due to the interaction of the parallel chargers. The charger supply voltage from the 4KW generator increases as each charger is added peaking at 124 volts so I don’t think it is a supply voltage problem.
110 amps is OK but what would it take to get a higher charge current? One charger rather than 3? I’m not really interested in separating the batteries during charging.
Does anyone know what is happening to keep the charge rate low?
I sent the question to Battleborn. Will post their answer if I get one.
