Having Email, Text Messages, Notes, Photos as well as PDF's, Doc, and more are kind of cool. But did you know you can print from your iPhone to a PRINTER? Something new is called AirPrint.
Here is what you need to know to send PRINTED Documents to PRINTER.
NO, THIS is NOT USING WIFI, but you are using printer and iPhones Bluetooth. The Printer you are using MUST BE CAPABLE FOR AirPrinting. You can find a list of AirPrinters online.
First, you need a Printer called "AIR-PRINTER" which can be a laser printer or Ink-Jet printer. Whatever they do have to be AirPrint capable.
1. Turn on your iPhone and go into SETTINGS
2. Go into SETTINGS, Turn on BLUETOOTH as well as on your Printer.
You don't need your WIFI to perform this AirPrint.
3. On iPhone go to the Document you want to print out.
4. The Doc can be in NOTES, BOOKS, Email any shown above. To find the doc and open that document. NOW look for a SQUARE BOX with an Arrow going out of the top. CLICK on that iPhone symbol Box with the arrow.
5. PAN down to Printer and click (Now on your iPhone start a BLUETOOTH Search for the PRINTER and will list it on top.
6. Once you see the Printer Name and ID in the Box select the number of copies you want and click PRINT.
---------------------- NOW HOW TO PRINTOUT A TEXT MESSAGE ---------
Now how to capture a TEXT MESSAGE and save it to your photos, for example, say you need to make a printout of a TEXT message.
1. First Open your TEXT MESSAGE you want to printout. You will need to take a picture. So while viewing selected TEST MESSAGE, Click one button on the right side at the same time as the menu button center bottom press both at the same time, while viewing the TEXT MESSAGE.
2. Now you have a Phone of your TEXT MESSAGE. So go into your photos and click the text message photo. Look on Bottom Left for the square box with the arrow on top and press.
3. Follow the same steps starting at step 3, above.
GOOD LUCK ENJOY the iPhone Tip.
