rowiebowie
Senior Member
I have a disconnected Cat5 cable (previously used to power the now disconnected Sunexplorer solar monitor) that runs from the power side of my Avenue to the other side where I'd like to install a USB charger outlet.
I really don't want to "do it right" and try run new wires across the van to the opposite side because the difficulty just wouldn't be worth it in my opinion. Would the 8 wires within the old Cat5 (ethernet) cable provide the 2.4A required to power the USB outlet?
If so, how would I wire it since the 8 wires are individually insulated? 4 for positive & 4 for negative? All 8 positive and find a separate ground?
If this is the most stupid post you've ever seen, you can tell me. I'll only cry a little bit.
