Old 09-11-2022, 07:50 PM   #1
Default Internal Paneling Maintenance
Does anyone know how to remove interior paneling fasteners without doing damage, or is it even possible? The fasteners themselves are covered with the same fabric as the panel itself.
Thanks
Jim Agile is offline   Reply With Quote
Old 09-11-2022, 11:16 PM   #2
Those are common decorative screw head covers. Just put a screwdriver under an edge and pry up - they will pop right off. Or, use a plastic tool for this purpose. This will expose the underlying screw head. Go gently so as not to damage the surrounding fabric material.
Old 09-12-2022, 12:33 PM   #3
For under $10 from Amazon or the local auto parts store it's worth owning a set of plastic trim removal tools so you don't scrape up your panels.
Punkinhead is offline   Reply With Quote
Old 09-12-2022, 04:24 PM   #4
Thanks, good to know.
Old 09-12-2022, 04:25 PM   #5
I am ordering a set of these. Thanks for the tip.
Old 09-12-2022, 06:57 PM   #6
When using any of the removal tools on a soft or fragile surface it is good to use a something to protect the surface and spread out the load. Old credit cards or drivers licenses even work pretty well. I use a small piece so plastic sheet about the same thinkness as the credit cards, but larger, very fragile surfaces and a small piece of aluminum sheet on hard surfaces and hard to pry off retainers.
Old 09-18-2022, 05:55 PM   #7
Thanks for all the good advice. Does anyone here have a link (Amazon?) for replacement fabric covers?
Thanks
-David
david@davidfischer.com is offline   Reply With Quote
Old 09-18-2022, 09:32 PM   #8
Check a local auto upholstery supply. They won't have the buttons though. Save the buttons. I re did mine (grey) with auto vinyl they suggested and I was successful getting matching vinyl buttons on Amazon. It wasn't easy; though the steps sound easy. The panels that curve are the hardest to get smooth and you really get just one chance when using the glue. You will need to buy or retain foam backing for this also.
tarp is offline   Reply With Quote
Old 12-04-2022, 08:32 PM   #9
Default Thank you all!
Great conversation - and just what I was going to ask; "How do you get the buttons off so you can pull wire, etc."
A real wealth of experience here. Thanks and,
Cheers - Jim
phantomjock is offline   Reply With Quote
fasteners, interior finishing
