RV Weight Terminology
markopolo-ClassB
Senior Member
Joined
Oct 24, 2006
Posts
8,828
Location
New Brunswick, Canada
By Mark Polk
Everyone should have a basic understanding of weight terms. Do your research to avoid becoming a statistic in relationship to overloaded RVs.
Gross Vehicle Weight Rating (GVWR):
The maximum permissible weight of the vehicle when fully loaded for travel including the vehicle, cargo, liquids & fuel, passengers, and any towed vehicle tongue weight. Motor homes, tow vehicles, and trailers all have GVWR.
Unloaded Vehicle Weight or Dry Weight (UVW):
The actual weight of the trailer or truck as built at the factory. The UVW does not include passengers, cargo, fresh water, LP gas, or after market accessories.
Cargo Carrying Capacity (CCC):
The maximum permissible weight of personal belongings that can be added. CCC is equal or less than GVWR minus UVW, full fresh water weight, and full LP gas weight.
Gross Axle Weight Rating (GAWR):
Every axle has a GAWR. It is the maximum allowable weight that the components (tires, wheels, brakes) of each axle are designed to support.
Gross Combined Weight Rating (GCWR):
The maximum permissible weight of the tow vehicle and trailer combined when both are fully loaded for travel. GCWR also applies to a motor home towing a vehicle or trailer behind it. GCWR minus GVWR represents the allowable weight for the towed vehicle. Note: The hitch receiver mounted on the towing vehicle must be rated for this amount of weight. If it is rated for less that is the maximum amount you can tow.
Gross Vehicle Weight or Gross Trailer Weight (GVW), (GTW):
This is not a rating; this is the actual weight of the tow vehicle or trailer when they are fully loaded for travel. This includes the vehicle, cargo, liquids & fuel, passengers, and the towed vehicle’s tongue weight.
Hitch Weight or Tongue Weight (TW):
The amount of weight pressing down on the vehicle’s hitch or 5th wheel connection when the trailer is fully loaded for travel.
Happy Camping
Mark
RV Expert Mark Polk, seen on TV, is the producer & host of America's most highly regarded series of DVD's, videos, books, and e-books. www.rveducation101.com/
Sign up for your free "RV Education 101" Newsletter rveducation101.com/email/
Article Source: http://EzineArticles.com/?expert=Mark_Polk
  • and much more...
Try RV LIFE Pro Today
Back
Top
