I'm assuming by now you got your answer how to remove your Pot Drawer, but if not I have a Slumber and can tell you.We have a Roadtrek Play SRT. Much like a PLAY or ZION. We need to winterize it using anti-freeze. We want to access the pump which is behind the big drawer under the fridge. How to remove the drawer? Thanks
Wait... A Play SRT? That doesn't even show on the Roadtrek website, nor have I read of their offering any SRT models other than the Zion SRT with the new company. Since the Play is an upgraded Simplicity... presumably a Play SRT would be an upgraded Simplicity SRT.We have a Roadtrek Play SRT. Much like a PLAY or ZION. ....
Pull the drawer out to the extent of its travel. There is a small latch/lever on each side, in the track assembly. Push the latch on one side up and on the other side down. Then the drawer can be pulled out.https://youtu.be/7FNWBBrRIAc
