Old 04-17-2023, 06:43 PM   #1
Default New Elwell / Timberline Diesel heater system
New in box. I bought 5 of these and only built 4 vans.
I have used Espar and Heatso and the Timberline system is superior. For one it does not require that you adjust the mixture for altitude.
The Timberline is designed specifically to provide premium heating and hot water in even the most adverse climates. This system efficiently manages energy based on the users desired comfort level using the diesel-fired Autoterm Binar Compact heat source, which is optimized for seamless use at high altitudes and sea level. Comfortable heat is provided by automated air handlers that run softer or harder depending on the climate’s demands. A supplemental 120V heating element is also available for use when the motorhome is plugged into shore power.
The retail price of these systems is $4000 not including taxes and shipping.
I am selling this one unit with all installation parts and fans and glycol tank, etc for $3500.
Give me a call.
Curt 415.785.3757
ableami is offline   Reply With Quote
