Old 09-29-2007, 12:55 AM   #1
g1g
Default Generator Problem
My Onan 2.8 in my 1995 B won't start. It has spark but no fuel coming out of the fuel filter. Has plenty of gas getting to the Generator. I haven't checked the fuel filter yet because I don't have a replacement and hard to get to.
My first question is does it have a fuel pump on it?
Second one is do I have to drop it down to change the fuel filter?
The line is short so I am not sure I can get a new one in there.
Old 09-29-2007, 02:44 AM   #2
Default
An Electric fuel pump is listed as a Standard Feature on the Specifications Sheet for the Microlite 2800.
Old 09-29-2007, 03:07 AM   #3
g1g
Default
Marco, you realize that's not what I wanted to hear. I had it all thought out on how to fix it with gravity feed. It looks like I will have to drop it now for sure unless I take it in.
Thanks for the info.
Old 09-29-2007, 03:26 AM   #4
Default
One person on the RT Yahoo Group posted that you can change the fuel pump without dropping the generator but you have to be able to get the generator cover off.
Another posted he used a pallet jack to drop the generator.
Just a thought, did you check the oil level? The low oil shut-off would prevent it from starting. (I know you're pretty sure it's a fuel problem).
Old 09-29-2007, 03:37 AM   #5
Default
This guy (I think his name is Chris) replaced the carb without removing the generator:
http://www.cassidy-online.com/comvee/index.html
his generator photo:
http://www.cassidy-online.com/comvee/pi ... G_1758.JPG
Old 09-29-2007, 05:52 PM   #6
Default
Higher resolution photo here:
Thread Tools
Display Modes
