Old 11-25-2006, 03:29 PM   #1
Ron
Default Re: Laptop Workstation Swivel Table 2002 Dodge RoadTrek
Following are 18 photos of a Swivel Laptop Workstation Table I made for my 2002 Dodge RoadTrek, one can also be made for the Chevy RT's
PHOTO: # 001:
01: Table Top= 14 3/4" x 11 1/4"x 3/4"= [12 inch Board] For Laptop Workstation Table
02: Table Support Brace Bracket = 12 1/4" Long - 1 1/4" Wide - 1/2" Thick
03: Board= 7 1/4"x 12"x 3/4" = [8 inch Board]
04: Board= 7 1/8"x 4 5/8"x 3/4" = [8 inch Board]
05: Board= 11"x 9 1/4"x 3/4" = [12 inch Board] Extension Shelf For Mouse & Mouse Pad
06: 1= 2"x 4"x 5 1/2" Tapered 2 x 4 Board-Mounting Block
07: 1= 2"x 4"x 4 3/8" Tapered 2 x 4 Board-Mounting Block
PHOTO: # 002:
01: Board= 7 1/4"x 12"x 3/4"
02: 1= 2"x 4"x 5 1/2" Tapered 2 x 4 Board-Mounting Block
03: 1= 2"x 4"x 4 3/8" Tapered 2 x 4 Board-Mounting Block
04: 2= 10-24 Tee Nuts 1 for each Mounting Block
NOTE: Each 2"x 4" Mounting Block is notched for 10-24 Tee Nuts to be inserted
PHOTO: # 003:
01: 3= 1 1/4" Wide Angle Brackets - Strong Tie
02: 1= Plywood Sheeting Clip
03: 4= 2 inch 10-24 Machine Round Head Slotted Screws
04: 4= 2 1/2 inch 10-24 Machine Round Head Slotted Screws
05: 2= 1 inch 10-24 Machine Round Head Slotted Screws
06: 4= 1 inch #6 Sheet Metal Screws
07: 8= 3/4 inch #6 Sheet Metal Screws
08: 6= 1/2 inch #6 Sheet Metal Screws
09: 4= 1 inch Wood Screws
10: 8= 10-24 Wing Nuts
11: Numerous #10 Flat Washers
12: Numerous # 10 Lock Washers
13: Numerous #8 Flat Washers
14: Numerous #6 Flat Washers
15: 4= 3/4 inch Dowels - Drill through center use 13/64" drill
16: 1 Rotating Plate with Ball Bearings - Snaps/Stays In 4 Positions
17: 2= 3 inch Corner Brackets
18: 3= 2 inch Flat Corner Irons
19: 1= 2 inch Mending Plate
20: 2= 10-24 Tee Nuts
21: 1= Table Support Brace Bracket = 12 1/4" Long - 1 1/4" Wide - 1/2" Thick
PHOTO: # 004:
01: Laptop on Workstation Table Facing Drivers Seat
02: Laptop secured with 2 bungee's for more security
03: Laptop secured with 2" Flat Corner Irons & 2" Mending Plate- 3/4" Dowels
04: 3/4" Dowels drilled through center for 10-24 Machine Round Head Slotted Screws
PHOTO: # 005:
01: Laptop on Workstation Table Facing Front Passenger Seat
PHOTO: # 006:
01: Laptop on Workstation Table Facing Drivers Seat with Extension Shelf for Mouse & Mouse Pad
PHOTO: # 007:
Laptop on Workstation Table Facing Rear with Extension Shelf for Mouse & Mouse Pad
PHOTO: # 008:
01: Red Tip Pointer showing Dell Laptop Power Adaptor
02: Power Adaptor secured with 8" Magic Ties onto Table Support Brace
Bracket
02: 2 Bungee's secured on Screw Eye, Screw Eye secured onto Workstation 7 1/4"x 12"x 3/4" Baseboard
03: 2 Bungee's secured to bottom Engine Cover Floor Clamps
04: Table Support Brace Bracket top secured onto Baseboard with 1 1/4" Wide Angle Brackets - Strong Tie
05: Table Support Brace Bracket bottom secured onto bottom engine cover storage area lip with Plywood Sheeting Clip
PHOTO: # 009:
01: Same Information as Photo #4
PHOTO: # 010:
01: Laptop Power Adaptor plug connected to 300 Watt Inverter
02: Overhead Under cabinet light connected to 300 Watt Inverter
PHOTO: # 011:
01: Bungee passenger side secured on Screw Eye onto Workstation 7 1/4"x 12"x 3/4"Baseboard & secured to bottom Engine Cover clamp
02: Rotating Plate with Ball Bearings - Snaps In Position connected between 7 1/4"x 12"x 3/4"Baseboard & 7 1/8"x 4 5/8"x 3/4" Board which is secured to Workstation Table
03: Workstation Table attached to both Tapered 2"x 4" Mounting Blocks
04: 2"x 4" Mounting Blocks sitting in cup holder & Ashtray holder of engine cover
PHOTO: # 012:
01: Power Adaptor secured with 8" Magic Ties onto Table Support Brace
Bracket
02: 2= 3 inch Corner Brackets secured to both Tapered 2"x 4" Mounting Blocks, & 7 1/4"x 12"x 3/4" Baseboard
PHOTO: # 013:
01: Table Support Brace Bracket bottom secured onto bottom engine cover storage area lip with Plywood Sheeting Clip
PHOTO: # 014:
01: Overhead Under Cabinet Light 13 inch, 8 Watt Fluorescent Light attached to Overhead Storage with Industrial Velcro
02: Light works on both AC and 300 Watt Inverter
PHOTO: # 015:
01: Rotating Plate with Ball Bearings - Snaps/Stays In 4 Positions, connected between 7 1/4"x 12"x 3/4"Baseboard & 7 1/8"x 4 5/8"x 3/4" Board which is secured to Laptop Workstation Table
PHOTO: # 016:
01: Rotating Plate with Ball Bearings - Snaps/Stays In 4 Positions, connected between 7 1/4"x 12"x 3/4"Baseboard & 7 1/8"x 4 5/8"x 3/4" Board which is secured to Workstation Table
PHOTO: # 017:
01: 2: 1 1/4" Wide Angle Brackets - Strong Tie attached to Laptop
Workstation for back of Laptop, secures Laptop
02: Screw Eye secured onto Workstation 7 1/4"x 12"x 3/4"Baseboard
03: 2= Tapered 2"x 4" Mounting Blocks notched exposing 10-24 Tee Nuts, 2, 1 inch 10-24 Machine Round Head Slotted Screws screwed through 7 1/4"x 12"x 3/4" Baseboard into 10-24 Tee Nuts of Mounting Blocks
Note:
01: Laptop Station Table swivels left and right, individual can exit seats
comfortably
02: Extension Shelf for Mouse & Mouse Pad secured to Laptop Workstation with 2, 2 inch 10-24 Screws, and 2, 10-24 Wing Nuts, very secured
03: Laptop Station Table can also be used for a small portable TV or a DVD Player
04: Both Laptop and Overhead Under Cabinet Light operate on AC/DC
05: Dowels can be taken off of Laptop Station Table, and a small serving tray can be put ontop of Laptop Station Table
Ron & Rose Cabral
New Bedford, MA
2010-Chevy/RT-190P
FMCA:303873 ~K1RRC~ RRRCRT@aol.com
Ron is offline   Reply With Quote
Old 11-25-2006, 04:00 PM   #2
Default
Wow! Ron - great job. Thanks for taking the time to detail the construction and parts list for your Laptop Workstation Swivel Table.
You've made it easy for people to do this themselves.
It looks very secure to me and it really doesn't take up much space. I like that it can put to other uses such as providing a flat surface for a serving tray.
Old 11-25-2006, 08:37 PM   #3
Default
Julie - I think your modification deserves it's own topic so I moved it here:
Julie & Chino's Pleasureway Modifications
Hope you don't mind.
Old 12-10-2006, 01:59 AM   #4
Default
Nice job Ron.
I like the versatility of the laptop table to be used as a snack table too on the same table. The cup holders prevent spillage of the drinks on the laptop as well.
Please tell Rose that she should go into the business of setting up displays for professional photographers. Excellent work!
joe
Joseph & LaVada Studley
2004/05 Chevy Versatile
F380826
https://www.rv.net/glb/cfb/memberphot...VisitedMap.jpg
2004
Roadtrek 190 Versatile
FMCA F380826
joeRT04 is offline   Reply With Quote
