Installed new 275-70R-17 tires onto the 17 X 7.5 28mm offset Chevrolet alloy wheels today. Before I did I reinstalled the 2 inch steel wheel spacers on the rear axle, so the rear track is just barely wider than the front now.
Here are 3 views -
As I bought it, stock ride height, American Racing AR-23 factory wheels with 245-75-16 tires-
After lifted 4 inches, 16x8 0mm offset American Racing ATX Ledge wheels with 265-75R-16 tires BF Goodrich T/A KO2 tires-
As it sits now- Chevrolet 17X7.5 28mm offset wheels with 275-70R-16 BF Goodrich T/A KO2 tires-
The front on the ATX Ledge wheels -
And with the Chevy wheels- the 28mm of offset brought the tire edge in about an inch-
Tuned all the way in, no interference-
turned out, about an inch to spare-
I think it looks best with these factory wheels
With the new wheels & tires it felt like a different vehicle! Slow speed turning was much better (less scrubbing) and at city speeds it drove great. I took it briefly onto the interstate but the winds were really blowing so I couldn't get a really good feel of the change but it did seem more planted.
I'm not sure if these tires would fit on a stock van or Roadtrek because the lift spindles in the front do push the wheels out some and I'm using spacers on the rear. As Booster has said he's had success using the stock offset wheels with 265-75R-16 tires.
If I was to recommend an aftermarket solution I would try to get a wheel with as close to the stock 28mm offset as possible. I found a lot of wheels with 20mm of offset and a few with 25, but I really had to search for them.
Thanks for all of your research & help Booster!
