themexicandoctor
Senior Member
- Joined
- Dec 20, 2011
- Posts
- 1,619
Evening,
Guys I have spent months trying to renter this forum and website, I know very little about computers and I have just invested another three hours trying to put this together.
I cannot find my drafts that were saved, I have been redirected to God knows where and this is not valuable to me but I owe you guys the favour after climbing on your backs for so long.
I AM NOT going to learn how to do the photos here and now, I may never will.
Just email me at themexicandoctor@hotmail.com or mark@thewakefieldinstitute.com
And I will gladly send you anything I have.
Moreover, CALL BILL, he's the expert, I am just the beneficiary.
I have tried to answer the questions as they are listed below.
Hope this helps ... Wakefield
from BOOSTER
Interesting stuff. What did he do different than Tufftruck on the springs? Springrate, length, etc.
DONT SCREW AROUND WITH THESE MANUFACTURERS, THE MARKET IS TOO SMALL, SEE BELOW
When I first began this project I called Randy (great guy/total failure for me/two times/pissed me off), at Otto Max because of what I saw was your endeavours, at this stage there was about half the posts you have now.
Told him what the issue was and he said no problem, he knew of the issue and was looking to trial his new coil springs, that he would send me down a set of coils at no cost (to Supersprings of Santa Barbara who had lifted the rear) and lets see what happens.
I drive round trip 250 miles, spend half a day waiting for the Mechanic to get the Coils in, only to find they are too short!
Before I even put them in, I called Randy several times and took photos of them standing next to the original springs, they looked too short but Randy assured me that once they are in they will be longer, blah blah blah.
They ended up shorter.
And then another half a day to put the originals back in.
The Mechanic's cost was graciously absorbed by Gerry at Supersprings, close to $450-600!
Then I tried some other ideas, again, half a day later tearing the front end off and the expert is scratching his head and saying what I want done, cannot be done.
Then a few months ago, maybe February in frustration I call Randy to see if he ever got around to getting his latest improved version of coils made.
He is ecstatic, yes he has the Coils and he will send a set down to me by expedited delivery (I paid this time both ways $100), and I watch the installers try to get Coils in that just won't fit into the space provided and they are there for hours.
I sent him photos of everything including my swingarm, etc with the stamped id numbers
I am pissed, I call Randy and he starts giving me the run around saying he had personally gone to the GM Dealer and purchased the swingarm, etc and built the latest set of coils around these parts.
All BS!
But at first, not being an engineer, or maybe Roadtrek cut a corner, or GM made my individual truck on a Bad Monday (and that is why all these other 8 experts cannot rectify the problem), I get the GM Tech people onto the problem and they have all there experts checking the part numbers, etc .
I pay this Mechanic $500 cash, he gives me $100 back because he feels bad. I am still out overall $500 plus this time, two days.
A day later I get the Head Honcho Tech from GM tell me that everything at my end & theirs correlates for the 2004 3500 I own, that was put together by Roadtrek and sold as a 2005.
The verdict; Randy or OttoMax, with our particular needs, are pissing in the wind and pissed me off!
BRIAN
Did Bill change the arch of the factory leaf springs, along with adding a leaf?
You said the springs you ended up with would be too harsh for corrugated roads and uneven surfaces. I have that problem with the current TuffTruck springs. They are fine on smooth highways. They reduced pitching and rolling enough to remove the front swaybar. And they provided 2+ inches of lift. It sounds like you tried some of the things we have tried, and run into some of the same brick walls.
3) Sooooo, in you opinion, what is the difference between the Bill Erb coil springs and the TuffTruck springs?
Brian, I am Mechanical with some things but this is a science beyond me.
I believe he may have, in the process of putting the tired springs in the oven, strengthened and re-arched them.
And like I mentioned, he dismantled the rear overleaf system from Supersprings, painted it and put it back on. I mention this because he said every other system like this he has seen is bandaid designed to fail but he was very impressed with the roller system engineering & the overall design. But because of the weight of my truck (around 8500-8600 lbs), the damage caused by the tired springs, etc, within less than a year, Bill had to, while I waited, made new rubber parts & stronger than Teflon bushing parts.
Again, he liked the design and thought that keeping it, with the better than new leafs in the rear plus one & the new coils up front, it should only give me more support.
The difference; call Bill yourself and spend 5 minutes on the phone with him.
I knew within a minute.
Evening,
I will attempt to answer everyone's questions as they arrived.
FYI it took me a while to get back in, months in fact and another hour tonight.
It seems the username is case sensitive & I am internet frustrated, the only sensitiveness I have noticed about a case before is when beer came in wooden boxes & I sat down on one and the nail wasn't embedded.
Here is my email; themexicandoctor@hotmail.com or mark@thewakefieldinstitute.com
I am NOT going to attempt photos yet, I have an instantaneous temper and I struggling as it is.
Any photos, send an email to either address and I will send you the photos.
from BOOSTER
When I first began this project I called Randy (well meaning & great guy/total failure for me/two times/pissed me off), at Otto Max because of what I saw was your endeavours, at this stage there was about half the posts you have now.
I have been through the whole ambulance/diesel spiel, etc, but that is now, not then.
All BS!
BRIAN
Who else would tell you to come up on a weekend, open his factory on a Sunday, and just by reading the blogs here be able to overnight create coils that did everything we have been looking for (if you need more inches tell him), and tell me it would be done by afternoon and moreover, when we measured the vehicle afterwards, it was within 1/12th of an inch!
Ask him any question you want about your problem.
Use my name if you wish.
Tell him what you need.
He is a walking, talking, dreaming, independent Suspension Guru who for just a few hundred dollars gave me everything I needed and more - I would have paid five times the amount. As it is, I lost about $2000 before I even met Bill. Not including time & hair loss.
And a gentleman who doesn't do this for the money but the challenge - I got an incredible deal, I wanted to pay him more.
This weekend I will be installing a prototype set of coil springs, from TuffTruck.
The current TuffTruck springs are the same length as the factory springs, but they are much more stiff.
The prototype springs are 2" longer, and the spring rate should be lower. In the end, this should provide the necessary lift, while also giving a softer ride. I am looking to improve the ride on rough pavement and dirt roads.
I will be using an App for my iPhone that records the vibrations using the internal accelerometers or the iPhone. I will be able to compare the before and after effects of the modification. I will be doing this for the rear springs also, when that time comes.
BRIAN,
I am presuming these are the latest set that Randy keeps on promising to have had made, I was supposed to have these 3 months ago post my second experience with Randy. Randy is a salesman, not an engineer.
If he is an engineer, God help Canada.
I have the photos of your unit because he sent them to me a year or so ago and the fact you found them too tough.
You know how I feel about Randy & OttoMax but I am sure he is giving them to you free of charge.
I hope it works out and if it doesn't, you seek an agreement beforehand that they pay for any mechanical fees. And your time.
But maybe you are doing them yourself, in that case, God help Randy!
Don't trust me, call Bill first, see what he can do.
And then I noticed this from BOOSTER;
That will be interesting to see how it works. I seem to remember Tufftruck made some longer ones in the past, and that the guy that put them in said they bowed out badly. That kind of makes sense because they are the between the a-arms mounting with both mounting surfaces changing angle. You definitely will need a spring compressor to put them in.
BOOSTER
Rereading what themexicandoctor posted. He used KYB shocks in his upgrade, not the Bilsteins like we used. If they are like the other KYB Gas-adjusts I have used, they will do a very good job of controlling motion, but will severely harshen the ride. I actually just put a set in the Buick Roadmaster wagon, because I was too cheap to get Bilsteins, and it did get significantly harsher! We found the spring change to not harshen the ride all that much, but we went to the Bilsteins and Michelin MS2 tires at the same time, so that could definitely have smoothed us back out.
I used the KYB Gas Adjust Shocks, I had new tires installed b efore Bill called Equaliser Sport A/P, I got them for $80 each from my friend who owns a Big O Tire here in LA and he said the manufacturer had a very good name, I believe they are made in Japan?
Perhaps they are not perfect for the load characteristics and I will replace them with Michelins in another 20,000 miles or less.
I do run nitrogen only in them.
I assumed the slightly harsher ride in the rear was due to the 6 year old leaf springs going into the oven and the fact I added another, nothing more.
I would have gladly purchased the Bilsteins but everyone I spoke with said the Gas Adjust which are a higher grade of KYB will be fine, at 1/3rd of the price at shockwarehouse and come with a similar 5 year warranty. I am never cheap in solving mechanical issues, I only want the best.
I hope this helps guys, but Bill is the Guru and with your knowledge, you will know that in one minute. Call him.
And if you want photos, send me an email and I will gladly send you a whole bunch including before and after together with measurements, etc.
from BOOSTER
All BS!
BRIAN
Evening,
from BOOSTER
All BS!
BRIAN
BRIAN,
BOOSTER
