First Post to this Forum.
Last year I made the effort to replace the front springs and add rear air bags to my 2008 Roadtrek 210. The main objective was to increase the ground clearance. I used the information from other's experiences, mainly on this forum, to make my decisions on what parts to use.
Front springs were replaced with Moog 81004. Replaced the top spring seat with Mcquay-Norris 2613590
. Bought Moog K160021 lower spring seats that didn't seem right, so I reused the existing rubber sleeves. Had to disconnect the front stabilizer bar for the job so was going to replace the bar link bushings, but when looking at prices, decided to replace the link assemblies - Moog K700537.
OEM spring wire was 0.950 " dia.; Moogs are 1.031". OEM had approx. 7 1/2 coils; Moog about 8 1/2. Free lengths virtually the same at 14 3/4 ".
Installed Firestone rear air bags F2337. Wireless control system 2489 (now 2554?) to be installed later.
Thought replacing the coils was going to be the bigger part of the job, but it turned out to be the bag installation. There are brackets that attach to the bottom of the spring u-bolts. Nuts are included in the kit, however the thread was different than the u-bolt thread. Supplied nuts were metric; u-bolts were unified. Apparently, Roadtrek added spacers between the rear axle and leaf springs which required a change to longer u-bolts. I didn't think that adding nuts to the existing bolts would work because of the amount of rust present, so I replaced all the u-bolts and bought extra nuts for them. Not easy. Had to heat them glowing for a 3/4 impact to budge them and still had to cut two of them off.
The new front coils give a 2" increase in height and keep 50-70 psi in the rear bags to stay level. Stability and handling at speed much improved, accompanied by a somewhat stiffer ride - as expected.
Front toe needed big adjustment. Camber seems okay; haven't checked caster.
Very satisfied with results and would recommend these changes to anyone.
