Hi Everyone, I have been researching the Class B Travato 59K. I really like the layout of it. I'm concerned about the front wheel drive and the size of the motor being able to get up those big mountains out west. I would love to hear from you all about your experience on the power to the motor. Thank you and Happy Travels!
Having moved from a WGO ERA Sprinter w/diesel into a 2019 Travato, I was a little concerned about the gas v6 and front wheel drive. I’ve read (on promaster forum) that dodge slightly lowered the gearing in the promaster to help with the extra weight it is anticipated to haul. I suspect that maybe the lower gears were changed but my final drive seems normal at about 2200rpm around 70mph.
One thing I did notice different was the 6 speed trans on my Travato will downshift quickly when climbing an overpass or in rolling hills. My sprinter 5 speed didn’t shift near as often. But I’ve since gotten used to that.
I pulled a trailer a couple of times (not big maybe 1000lbs) and the sprinter was happier doing that but the dodge managed ok in “tow haul”.
I now have about 25k miles on Travato and I’m noticing the fuel economy is actually better now. I was averaging around 15 with a mix of 50/60% highways.
I’m now averaging 16+. Funny thing is I noticed that speed didn’t matter as much. I tried a tank on a trip at 60-65mph max. Then next tank at 70-75mph and it was the same. I suspect that the load (tourque) on the motor was a little more efficient running around 2500rpm. It also downshifted less at the higher speeds when approaching hills. Like I said my motor seems to be happier running around 2k-3k rpm.
In any case I’m happy with the highway economy once I got used to the downshifting on hills.
My sprinter got the same 16mph but using higher priced diesel.
My sprinter also had a propane generator that seemed to consume almost all my propane with 1 night of using a/c. I’d get maybe 25 hours then I had to go find a propane station to fill tank. And since it was permanent onboard tank I couldn’t just run down to convince store to swap tanks like I could previously on my old travel trailer. Royal PIA!
Gas gen on my Travato pulls from chassis gas tank so it’s so nice to just fill up at any gas station and I’m good to go.
Sorry for the long winded post - didn’t start intending to write a War & Piece novel.
So just a few comments more:
I love the K layout and large rear bathroom
Very happy with the overall size of van (shorter than my extended sprinter was)
Good luck with your new purchase - I hope you have many many memorable trips - I sure have.
