Old 02-05-2017, 07:29 PM   #1
Default Era (SeGi) window screens
The window screens on our 2017 Era 70X do NOT fit tightly. The clip design is just four roughly 3/4" plastic tubes on each screen that fit into the window frame.
The screens rattle, gap and slide fore and aft.
What have you other Era owners found to be a solution to this issue?
Hehr makes a wire screen clip that I like a lot. They work really well on our friend's Jayco 37TS Super C.
I do not know if the channels in the SeGi screens are wide enough to accommodate the Hehr clips.
Anyone tried this?
White Cloud is offline   Reply With Quote
Old 02-22-2017, 10:18 PM   #2
Thumbs up Update on Screen Clips
I tried the Hehr window screen clips on the SeGi window screens that came with the Era.
The Hehr clips fit with very little modification (narrowed the ends a little) and hold the SeGi screens very tightly in the window openings.
I've ordered all the remaining clips I need from Parkin ($1.23 per clip).
A MUCH better solution than either the original SeGi rubber clips OR bolting the screens to the windows as suggested by SeGi.
No more screen rattles and slips!
Old 04-10-2017, 01:19 AM   #3
Thanks for the info! I have a 2014 ERA and going to give them a try. Did you use the anti rattle clip part number 109-467?
GBUSMCR is offline   Reply With Quote
Old 04-10-2017, 01:36 PM   #4
Item is H010-416. I think I paid $1.23 each, but are online other places @$1.55 ea. Either Parkin Industries or Pellandent.
2017 Winnebago Touring Coach Era 70X
One spouse (Tutti)
Two Labradors (1 yellow - Max; 1 black - Rose)
