10-11-2016, 12:56 PM
Ubiquiti airGateway - small device for small RV's
Having a network in your van allows all of your smart devices - phones, tablets, laptops, GPS, etc. - to connect to that network and to the internet when available. I've had a functioning network in my RV for 6 years now and find it handy to have. With a second RV in the mix, it is time for me to deploy a second network solution.
I opted for an outdoor WIFI antenna on the van originally and it will remain on the van. It made sense to me to have that antenna outside of (and above) the sheet metal walls of the van for better performance. I'm not sure that outside equipment will be necessary on the fiberglass walled, OSB roofed Trailer. That's why I'll try low cost, easy to do solutions first.
I going to test two Ubiquiti airGateway units (as a bridge & ap) to create an in-coach network and link to the internet. I found several online posts about using an airGateway in an RV or boat but usually they are used as an indoor AP with more powerful, outdoor units like the Bullet, NanoStation & PicoStation.
I realize the airGateway units aren't really intended to be used exactly how I plan to but they are inexpensive to try & still useful if it all doesn't perform well and later have to be paired with outdoor equipment. I have one with an internal antenna (to use as an AP) and one with an external antenna (to use as a bridge) on order. I'll try them in both RV's and try the one with the external antenna with the outdoor antenna on the van. I'm not sure if they'll end up in the Trailer or the Van at this point.
Why the airGateway unit specifically?
1. They are very small (see photos copied from the web below) - I'm thinking of placing them where a normal sized router wouldn't go.
2. I found several reports of running them directly on 12V DC - it will be very easy to tap into DC power - no AC to DC POE injector needed. It will be more energy efficient to run these DC devices directly on DC power. They can handle input up to 24VDC. The pinout appears to be pins 4 & 5 positive and pins 7 & 8 negative.
3. Very low cost.
4. It will give me the setup I prefer - a bridge with its own radio and an AP with its own radio. (More info on separate Bridge and AP's in the the Winegard Connect topic: http://www.classbforum.com/forums/f2...nder-5816.html )
I'll post more once I've had a chance to set them up. Any tips from other airGateway users will be appreciated.
10-11-2016, 04:01 PM
The Ubiquiti products are awesome--I bet your plan will work very well.
A couple of thoughts:
--Ubiquiti devices (at least mine) work just fine powered directly from the coach 12VDC system. But, don't go hacking cables. You can get passive PoE adaptors cheaply. Here is a random one:
--Note that if you put either of these devices outdoors, they require the use of shielded Ethernet cabling, which isn't that easy to find. There are guys on eBay who will make up custom cables for you. Just test the shielding for connectivity (and don't go with the cheapest guy). The first one I got had the drain wire unconnected.
10-11-2016, 11:43 PM
Thanks for the info and advice.
There is a chance that one airGateway could end up under a vent cover on the roof of the Trailer. I do have shielded cable on hand:
I visually confirmed the drain wire is soldered at both ends.
Do you know if it is sufficient to only use shielded cable between the two devices and not additionally ground that drain wire on the van chassis?
I found this about the airGateway on the UBNT forums:
Both poe ports male and female have shielded connectors maintaining the ethernet cables' drain wire connection to ground.
I had been thinking of using some flat 8P8C cable as the power cable (no data, just power). I can use my meter to check to see if pins 7 & 8 are also grounded in the airGateways. If so, that would also connect the drain to van chassis.
10-12-2016, 12:21 AM
Not sure, but I bet the shield is connected to the negative side of the 12VDC. Been awhile since I did my install. Easy enough to check, as you say. Just be sure you don't ground at more than one point. You don't want ground loops.
Good point about shield continuity in the PoE injector. Don't know if the one I posted does that. The one I used was in a little metal box and it does pass the shield.
10-12-2016, 01:40 AM
I have the Airgateway and Bullet M2 setup. The shield/ drain wire is connected to (-) DC on both devices, no need to ground the drain wire to the chassis.
10-13-2016, 12:44 AM
Thanks for that info
10-15-2016, 01:30 AM
UPS delivered the airGateway & airGateway-LR today. It is a bit puzzling to setup because I am unfamiliar with both airOS and Ubiquiti terminology.
Very small device:
I'd appreciate any pointers as to how best configure these or how others do it with Ubiquiti equipment. I have it working but think there are other ways and maybe better ways to do the setups.
I have the airGateway-LR connecting to my WIFI/internet, the airGateway is connected to the airGateway-LR via Ethernet cable. Wireless clients connect to the airGateway and can access the internet.
Brief summary of my setup:
airGateway
Wireless tab: Access Point
Network tab: Bridge
airGateway-LR:
Wireless tab: Station
Network tab: Router, DHCP enabled, NAT enabled
If I disable NAT then I can't access the internet. Everything is on the same subnet - maybe that is why. I could set the airGateway-LR as Bridge also but then my guess is that I'd be relying on the campground WIFI for IP addresses for every device I have. I wouldn't have my own private network either. Maybe the airGateway should be set as Router with DHCP instead of Bridge.......... There's bound to be a "best" way to do it.
When the airGateway-LR is connected to the Engenius outdoor WIFI antenna on the van performance is a bit better than the Asus router flashed with DD-WRT. A similar number of networks are seen but the airGateway-LR sees most of them every time I scan.
Six successive scans with the Asus router flashed with DD-WRT setup saw 3,5,2,4,6 & 4 nearby networks. 8 different nearby networks were seen in total.
Six successive scans with the airGateway/airGateway-LR setup saw 9,9,9,8,8 & 9 nearby networks. 9 different nearby networks were seen in total.
10-15-2016, 02:25 AM
That is what I would do.
In our setup, we have a Ubiquiti Nanostation which corresponds to your airGateway -LR, and a Pepwave Surf Soho which corresponds to your airGateway.
The Nanostation is set up in Router mode. It gets its IP address via DHCP from the campground WiFi network. On the LAN side, it has a static IP address on its own network. NAT and DHCP are both enabled.
The Pepwave router is set up similarly to your LR. Its WAN connection can come either from the Nanostation via its static IP address, or from the tethered Verizon MiFi device. It switches automatically and will use the Nanostation whenever possible. It gets its WAN-side IP address from the Nanostation (or MiFi) via DHCP, and creates both WiFi and Ethernet networks on their own IP addresses (separate from that of the Nanostation).
So, there are a total of four networks involved:
1) the campground WiFi (source of WAN)
2) The Nanostation (only used for the Nanostation to talk to the Pepwave)
3) The Pepwave WiFi in the van
4) The Pepwave wired ethernet in the van
10-15-2016, 03:03 PM
Thanks for the help. What you describe is confirmed by Ubiquiti this help article: https://help.ubnt.com/hc/en-us/artic...ge-WiFi-Client
The computer in that doc could just as easily be a unit like your Pepwave - used to provide a wireless network in the van.
That's basically what I've been doing. The airGateway-LR is what I'm using instead of something like a Nanostation. The LR stands for longer range or long range. I'm using the basic airGateway (not LR) as you'd use the Pepwave, minus advanced features.
The setup does work but there's a noticeable lag when requesting a webpage. A test download took a long time to complete today.
My new setup this A.M. is much faster. Brief summary:
airGateway
Network tab: Bridge
airGateway-LR:
Network tab: Bridge
DHCP, DNS etc., is all seamlessly passing through from the upstream router. The performance is as good as if my PC was connecting directly to that upstream router. This looks like the best way to go if a private network is not needed in the van.
I'll try the following -
airGateway
Network tab: Router
airGateway-LR:
Network tab: Bridge
- to get a private network. If the lag in performance returns then I'll test both units alternately in Router mode but with a completely different private IP addressing scheme within this range: 172.16.0.0 - 172.31.255.255 instead of the much more common 192.168.0.0 - 192.168.255.255.
10-15-2016, 03:18 PM
Oops. Your last msg made me realize that I switched the roles of your two devices in my most recent post. I will edit the msg to correct so people don't get confused.
I suspect that you are right that bridge mode all around would provide the best performance. BUT, I suspect that there are significant negative security implications to doing it that way--you are essentially on the same LAN as the rest of the campground. You really want a bit of firewall in there somewhere in this day and age. I am no expert, but think it would be best to have at least one of your devices to be in Router mode.
This stuff is so hard to think about--too many moving parts. I think the entire value proposition of expensive products like WiFi Ranger (just one example) lies in sorting out this kind of thing and pre-configuring generic devices.
10-15-2016, 03:50 PM
I agree about the appeal of ready-to-go but more expensive solutions. They're likely best for most people if they don't want to take the time to really get into this.
I also agree about that added layer of security if I can separate most of my devices from all the other users on the same free WiFi. There's a firewall to consider also. That is turned off in both airGateway devices right now.
I'll get going on the other testing. With the Asus/DD-WRT repeater I use a different subnet for devices on the van WiFi and I haven't noticed any speed issues. That might solve it.
I'm having fun & learning.
10-15-2016, 08:21 PM
Specifying a different subnet solved the lag issue. Either device can be used as a Router with DHCP & NAT enabled. Speed was quite good with either device configured that way as long as connected clients were on a different subnet.
A key point might be to choose a subnet or entire address range that will be unique to what you'd likely encounter at campgrounds or other free WiFi if you want the additional security of using a Router.
I ended up choosing to use the basic airGateway (non LR) as the Router. The airGateway-LR simply takes the place of long Ethernet cable between the campground WiFi and my van's Router (the basic airGateway). The airGateway-LR's only job is to bridge the gap. In Station mode, the airGateway-LR (my Bridge) it seems to be invisible to WiFi scanners.
I don't know if this setup is best or not but it makes sense to do it this way to me.
10-15-2016, 09:23 PM
Sounds right to me.
I think for your needs, your setup is about ideal. I went with the PepWave because (a) I wanted fallback to the tethered JetPack MiFi device, and (b) I wanted multiple wired Ethernet connections (e.g., for our AppleTV).
Thanks for the detailed report.
10-16-2016, 01:43 PM
A comment of yours about the relative low cost of some Ubiquiti products was what led me take a look at their stuff on Amazon. $19 for the airGateway and $29 for the airGateway-LR on the Amazon.com - not bad! I paid a bit more on the CDN site but had a credit I wanted to use.
I've put other devices from my home network on this new dual airGateway setup and all is working well. We streamed several hours of Netflix & all the usual web surfing. It's working well & ready to be installed. I've decided to put it in the van so as to gain the advantage of using the outdoor antenna.
I'm just waiting for a few items to be delivered:
Final setup can be imagined as a long string:
fuse panel --> power junction box --> Ethernet cable --> coupler --> male POE power only port on airGateway --> shielded Ethernet cable from female combined POE/data port on airGateway --> combined female POE/data port on airGateway-LR --> spare Coupler to cap the powered male POE port on airGateway-LR --> antenna cable to outdoor antenna
That leaves two lan ports free - one on each airGateway.
Edit to add: both devices devices powered at 12.2V DC for all testing - no issues
10-20-2016, 03:41 PM
Just a warning note. Take care if not using Ubiquiti POE parts.
This link - https://community.ubnt.com/t5/Instal...DC/td-p/820852 - warns of a possible short by the positive voltage pins making contact with the negative polarity shielding band if not using Ubiquiti POE parts.
I set the coupler on a bed of silicone at a safe clearance distance. The now cured silicone prevents the coupler from being pushed in too far. It also helps bond the the two parts together.
The unused male POE port will have +12V and would be another potential electrical short. I wrapped it in electrical tape and secured the tape with a zip tie.
