2008 pleasure way battery disconnect switch and breakers
Hi. I just got a 2008 pleasure way Lexor in perfect shape. Just one thing. I can't find the main battery disconnect switch
Not sure if that's the issue but everything works with the generator on but only the sofa works in the living area with generator off
No lights, heater, pump, nothing
I found some fuses and breakers under the couch and passenger otoman but that's not helping. Even water and battery gauges not lighting up
Somehow can't find the main shutoff switch for 12 volt anywhere
Thanks!
