Old 11-12-2019, 10:58 PM   #1
Default Lithium Test JWB1
This is a test of (my first) new install thread and uploading of pics. FEEL FREE TO IGNORE.
And the side view:
Thank you.
JWBrown is offline   Reply With Quote
Old 11-12-2019, 11:11 PM   #2
It looks like the AGM and lithium batteries are tied together at the solar controller. I think that would give you a mismatch of voltages when off charge that might not be desirable as the lithium will be constantly charging the AGM. Does the solar have dual battery isolated outputs?
Old 11-12-2019, 11:23 PM   #3
Wow, that was quick. I have read with interest all of your posts and help to others on this board (thank you for that), so I am anxious to hear your thoughts when I post the entire thread later tonight. This is only the very first test of the post I plan to make with a lot more detail, as I wanted to ensure I knew how the forum software worked. The two outputs are indeed isolated from each other for exactly that purpose. When I post the real thread, you will see there is a lot more to the system than these two random pieces convey. Thanks again.
